LED lights for stairs, skirting in domestic dwelling | on ElectriciansForums
Discuss LED lights for stairs, skirting in domestic dwelling in the Domestic Electrician Forum area at ElectriciansForums.net
T
The Ghost
Just wonder if anyone has any ideas or used same for string/skirting mounted LED flush fitting lights?
Stair lighting in wood handrail or if stud walls led tape profile mounted in wall looks good, better not to see the led tape direct on as looks tacky. See companies like Monoled or gap lighting for help. If a job is worth doing, do it well. B&Q is not the place for quality light fittings ok for a home owner but trade! Better to be known for quality work and use quality marerials. Do it once and right first time otherwise replace it every couple of years which is not good for business reputation.
The problem with that is some customer seem to spend their money irrationally.
Reply to LED lights for stairs, skirting in domestic dwelling in the Domestic Electrician Forum area at ElectriciansForums.net
Thanks for you response, that makes more sense LEDs do produce less heat. I think i read somewhere that LEDs are more sensitive to heat, as in...
Hi, I am restoring an old art deco, wall mount medicine cabinet. The cabinet has an 18” fluorescent light tube on each side. Before I put a lot...
