led lights in bathroom help please | on ElectriciansForums
Discuss led lights in bathroom help please in the DIY Electrical Advice area at ElectriciansForums.net
paul777
hello
please can you advise me
i have bought led lights to install under my bathroom cupboards
could you answer a few questions for me please
1.converters should i put them inside cupboard or leave on top ?
2. use a pull cord switch to operate lights ?
3 should i put the converter in a waterproof junction box ?
4. i`m a little puzzled by this but the lights fit into a a bore hole you cut out of the cupboards
but surely if i do this the inner workings of the lights will be viable when you open the doors
and will restrict where you can put items in a safe place away from these lights ?
thank you Paul
( PS these are NOT led strip lights )
sensio
se 40560
electronic led converter
prim: 220-240vac, 50/60hz
sec:24vdc, max.0.625a, 15w
ta:20*c...45*c tc85*c ip44
we have 2 sets of these lights
1 converter per pack with 2 led`s per pack
=2 converters and 4 led`s
hello
thank you Paul
sensio
se 40560
source of SELV to be outside the zone...
thank so much for replys
just a thought !!
what if i leave transformer in loft space then run 2 core cable to to led lights then /switch
thank you again Paul
just a thought !!
you should be switching the 230V side , not the selv.
Reply to led lights in bathroom help please in the DIY Electrical Advice area at ElectriciansForums.net
Hi all, I have a couple of questions I'm hoping you can help with. I have put a solar panel on my kids play house which charges a 12v battery. I...
