Discuss Led lights / light switch in the UK Electrical Forum area at ElectriciansForums.net
I think you've answered your own question there.Hi,
I've fitted four 3w led spots to my bedroom. My touch sensitive light switches only work with a minimum of 40w load.
Any ideas please?
ps... Don't say add another 10 spots.
Agreed. If the lights don't work with the switch you need to change either the lights or the switch.er.... change the dimmer or refit the original lights?
Maybe add 30W some other way, like a picture light.
It's a good idea but I think you'd have a job trying to match a halogen to the LEDs.Or if they are GU10 leds remove one LED and fix a 50W halogen?
Is this REALLY so difficult??!! Just change the switch for a compatible one!!
The switches are the expensive touch sensitive remote control ones. I could change the switch in the bedroom but the real reason I asked is because eventually I would like to change the spots on the landing to led lights which are controlled by four intermediate switches ( the expensive ones)
Just thought there could be some way of increasing the load to the switch some other way.
Reply to Led lights / light switch in the UK Electrical Forum area at ElectriciansForums.net
