LED PIR flood with override | Page 2 | on ElectriciansForums
Discuss LED PIR flood with override in the UK Electrical Forum area at ElectriciansForums.net
Leesparkykent
Nearly Esteemed
Kent
Any one have any recommendations? Don’t really want one where you have to flick on and off multiple times to override.
That Timeguard one has the most comprehensive instructions I've ever seen! usually it says "To mains the be connection doing, at best for it, you can." With a crappy wee diagram that's illegible.
This Timeguard one even shows you which way to turn the screwdriver to tighten the mounting screws! (5.7) and you also get a Knob Adjuster, 8.3...
I'm a big fan of Brackenheath, Lee. At the top end, price wise, but they do them with a good microwave sensor....about a 300 degree pick up.
[ElectriciansForums.net] LED PIR flood with override
Philips do a new one with remote control, you can set all the settings via remote and manually over ride it from remote too. can adjust sensitivity, lux etc and brightness too. they have it kew electrical was about ÂŁ30. a few weeks back
philips remote control pir light
Reply to LED PIR flood with override in the UK Electrical Forum area at ElectriciansForums.net
This contactor you suggested unfortunately only has two NO switches rather than 1 NC and 1 NO required for the CR3 current sensing bypass...
That will work fine as long as the Pirs use relay switching, some don't.
