LED possible strip lighting above worktops (under wall units) | Page 2 | on ElectriciansForums
Discuss LED possible strip lighting above worktops (under wall units) in the UK Electrical Forum area at ElectriciansForums.net
England
Hi, more advice required, about LED lighting. I'm so well out of date with these things. An Ashley/Rock HAL 96T batten holder was all that was needed in my time!
If you were posh, a fluorescent strip light!.
I intend to install LED lighting above the worktops. I looked at a video clip yesterday illustrating LED strip lights on a tape which is wafer thin. How do you typically wire them? Where would the transformer/ driver go?. At this point in time, I've wired a 1.0mm T+E cable from a spur point in readiness. I want to wire it neatly, nothing on show etc. Thanks once again,
Reply to LED possible strip lighting above worktops (under wall units) in the UK Electrical Forum area at ElectriciansForums.net
Switch by the door, pendant holder and a 100W bulb, some will remember, others weren't born yet when it went out of fashion, but this was the...
