Hey all,
I installed two LED SAL double spot lights (with no sensor) and the customer rang and said they are glowing at night when the switch is off. I looked in to it and i found the term ghosting. They are not two wayed but they are switched together.
Has any one eles had this problem?
What did you do to fix it?
I read that a zener diode may fix it. if so how would i install it? would i put the diode at the light terminals? (across the sw active and neutral).
thank you for your help
