LED spot light glowing at night when switched off | on ElectriciansForums
Discuss LED spot light glowing at night when switched off in the Lighting Forum area at ElectriciansForums.net
Australia
Hey all,
I installed two LED SAL double spot lights (with no sensor) and the customer rang and said they are glowing at night when the switch is off. I looked in to it and i found the term ghosting. They are not two wayed but they are switched together.
Has any one eles had this problem?
What did you do to fix it?
I read that a zener diode may fix it. if so how would i install it? would i put the diode at the light terminals? (across the sw active and neutral).
thank you for your help
Hey all,
Did you use quality lamps.
The challenge with LED lamps is that they need a miniscule amount of current and voltage to start to tickle them, and often this can 'disappear' under normal testing due to the impedances of meters. Induced voltage from adjacent laying cables is normally the culprit, although you might try changing the switch too, just in case. I don't know what off-the-shelf products exist in Australia to combat this, but in the UK/Europe we use 'snubbers' which are inexpensive and simply 'drop' the residual forward voltage on the cable to below threshold levels.
Awesome. I’ll grab a snubber. Thanks mate
Thank you.
Your "wide view" of suggestions might help me sort out an issue I am having with erroneous testing here in Ireland.
Check out my post on that topic.
RMS Electrical
Reply to LED spot light glowing at night when switched off in the Lighting Forum area at ElectriciansForums.net
In addition to Brians post above you can get electronic impulse relays, so no thud as they switch in and out.
Assuming the electrician checked the new driver was capable of supplying current (in other words it provided an output voltage and curent when...
