LED spotlight fault. | on ElectriciansForums
Discuss LED spotlight fault. in the Lighting Forum area at ElectriciansForums.net
L
Liam Adekoya
I have installed three LED spotlights with two way switching, one switch at the top of the stairs and another at the bottom of the stairs. The lights worked fine for about a week but now you can only use one light switch at a time, if the light is on you can turn it off with either light switch but can only turn it back on with the switch you turned it off with. To use the other light switch you have to turn the light on then turn it off with the other light switch. If anyone can help me or put me on the right path to where I went wrong it would be greatly appreciated.
If the light has been working fine for a week then a wire may have come loose. As above, check your connections in the switches and the lights
Reply to LED spotlight fault. in the Lighting Forum area at ElectriciansForums.net
In addition to Brians post above you can get electronic impulse relays, so no thud as they switch in and out.
Also posted in DIY. strange one in my kitchen. 3 sets of 2-way switched mains GU10 Philips down lighters. ( no dimmers) Have been fine for...
