Have customer who has staircase led lights if switched on and off within few seconds the rcbo trips, if switched on left for few seconds then switched off no problems, i am assuming the surge by transformer is issue ?
Indoors? Is the rcbo dedicated to this, or is it an up or down lights rcbo? 6A? Or something else?
I'm a bit surprised if it's a current surge, but suppose that's possible. Maybe earth leakage for some reason?
Any chance of trying a different driver, or is it a mystery bespoke setup!
It would be unusual for this type of lamps to have an earth connection, so I suspect it's an earth -neutral fault on another part of the circuit, or any circuit protected by the same RCD.
Edit: I see the OP says RCBO, so it could be inrush, but I'd IR test first.
Reply to the thread, titled "led staircase lights" which is posted in Lighting Forum on Electricians Forums.
