ghost3h
Hi, I am looking for some advice on what would be required for LED Strip lighting in my kitchen. The electrician ran cables from all the points (4) to the light switch. After looking online, I think I will need the following, and the electrician be able to connect it in the following manner:
RGB Strip lighting
Transformer (80w)
LED Driver (with remote)
Connectors for LED strip to 3core
Connect the Transformer to a plug under the counters and then the LED Driver, then connect these to cables and use the light switch as a circuit breaker for entire loop. Image shows my kitchen layout with cables and strip lighting.
Will the above work?
RGB Strip lighting
Transformer (80w)
