Fitted several strips of led tape lights,wired in parallel,connections at each 1. Driver is ok,tested voltage,also used a led strip also to test,this worked fine.but all lights not working,voltage present at each connection,still no joy,any ideas
Discuss Led tape lights in the UK Electrical Forum area at ElectriciansForums.net
If it's those snap on white plastic connectors I've had loads of bother of with them on the new LED tape I've been using, pot luck whether they light the strip up or not. I pre solder 100mm of 2 core onto the ends now with a bit of heat shrink over the top and just cut them to final length on site.It's bad connections between the connectors and strip.
Clean the LED strip ends more where the connector fits.
Reply to Led tape lights in the UK Electrical Forum area at ElectriciansForums.net
