Led tape lights | on ElectriciansForums
Discuss Led tape lights in the UK Electrical Forum area at ElectriciansForums.net
cliffed
Worcester
Fitted several strips of led tape lights,wired in parallel,connections at each 1. Driver is ok,tested voltage,also used a led strip also to test,this worked fine.but all lights not working,voltage present at each connection,still no joy,any ideas
It's bad connections between the connectors and strip.
Clean the LED strip ends more where the connector fits.
If it's those snap on white plastic connectors I've had loads of bother of with them on the new LED tape I've been using, pot luck whether they light the strip up or not. I pre solder 100mm of 2 core onto the ends now with a bit of heat shrink over the top and just cut them to final length on site.
Those snap on connectors are useless.I fit a lot of tape on a temporary basis to bits of set and all the tape I use I solder 5/6 inches of cable to them. Because I put it on temporary I have xlr connectors on the end but if doing a permant install just strip back the plastic outer casing and solder cables onto the tape then heat shrink over the top
Keep away from the clip connectors they are evil lol
Reply to Led tape lights in the UK Electrical Forum area at ElectriciansForums.net
The company Liteplan do replacement modules: Liteplan – The UK's largest emergency lighting component supplier. - https://www.liteplan.com/ This...
What is the distance from the point outside the house to the shed?
