Looks like you'll need to split the circuit then.Just looked and it recommends 5 - FFS! And yes I ballsed up - was meant to write MCB in the title
Discuss LED'S keep tripping the RCD when switched off? in the Lighting Forum area at ElectriciansForums.net
if the op has replace the 10 for led why would he put and a splitting them to a different circuit . he must have a fault on one of the lap C88p gear .Looks like you'll need to split the circuit then.
See his response In post #10, manufacturers recommend five fittings per circuit.if the op has replace the 10 for led why would he put and a splitting them to a different circuit . he must have a fault on one of the lap C88p gear .
Reply to LED'S keep tripping the RCD when switched off? in the Lighting Forum area at ElectriciansForums.net
