LED'S keep tripping the RCD when switched off? | Page 2 | on ElectriciansForums
Discuss LED'S keep tripping the RCD when switched off? in the Lighting Forum area at ElectriciansForums.net
Just looked and it recommends 5 - FFS! And yes I ballsed up - was meant to write MCB in the title
Looks like you'll need to split the circuit then.
if the op has replace the 10 for led why would he put and a splitting them to a different circuit . he must have a fault on one of the lap C88p gear .
See his response In post #10, manufacturers recommend five fittings per circuit.
I suspect that the new LED lighting has a high crest factor, where Crest factor is the peak amplitude of the waveform divided by the RMS value of the waveform. So when a number of new LED fittings are supplied by the original mcb the electromagnetic functionality of the mcb detects the high total peak current and trips the breaker. The rms value is low and therefore there is insufficient Ohmic heating to cause the thermal functionality of the mcb to operate.
This is why there is a limit on the number of LED fittings per mcb size - you mentioned 5. I suggest you modify the wiring to power the lighting from 2mcbs, 5 LED strips on each. Or a higher current mcb if the wiring allows to power all 10 but this is not to be preferred.
[ElectriciansForums.net] LED'S keep tripping the RCD when switched off?
Reply to LED'S keep tripping the RCD when switched off? in the Lighting Forum area at ElectriciansForums.net
Exactly. I was going to ask on the earthing once he clears this boiler fault (suspect on internal component). OP mentions oil boiler but makes no...
Build up of Earth leakage from multiple machines and the planner just tipped it over the edge?
