length of pvc conduit run | on ElectriciansForums
Discuss length of pvc conduit run in the UK Electrical Forum area at ElectriciansForums.net
G
Gordie
Its been a while since I last worked with PVC conduit but I seem to remember you had to have an access box every so often. Can anyone remind me of the regs regarding this.
Reply to length of pvc conduit run in the UK Electrical Forum area at ElectriciansForums.net
You should have no problems with what you want but even if you install conduit the cable still needs to be UF cable which is approved for under...
This is an interesting issue. I agree with you however I took this to task with a scam inspector some years ago and we agreed to disagree that...
