length of ring main circuit | Page 2 | on ElectriciansForums
Discuss length of ring main circuit in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
i fancy paying it off the roll and then when its short i will get wholesaler to coil it back up and grovel to me for selling me less than i asked for!! if it is 100m then i donald ducked and will have a snotty pile of cable!!
Ha ha that i would love to see!! you with a massive pile of payed out cable all over your drive!!
Don't confuse length of ring with max floor area, I think the max length limited by volt drop is around 127M allowing design current of 20A
I said you explination of the formula was correct but where do you get your numbers from??
4 x 11.5 x1000 is correct but your Ib will not always be the max admissible current allowed but in a ring that is correct. however i cannot check your mV/a/m as i dont have the regs to hand.
volt drop for 2.5 is 18, using the mcb of 32a as Ib. kitchen ring main has got me thinking in a barn conversion, due to the above size rooms to a standard house. It is measuring out at about 53 metres, just applying the maths to it and getting my head around it
Reply to length of ring main circuit in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
https://www.amazon.co.uk/gp/product/B08CJ3VC79/ref=ppx_yo_dt_b_asin_title_o05_s00?ie=UTF8&psc=1 I use this, current clamps go round each outgoing...
I generally thought double stack boards were more for situations where a portrait design is better suited to the cupboard - you still generally...
