length off flex you can ad to an appliance | on ElectriciansForums
Discuss length off flex you can ad to an appliance in the Australia area at ElectriciansForums.net
M
marty1234
hi what length off flex can you add to an appliance ie washing machine,tumbel dryre, i cant find any thing in the reg just had a quick look .
i was on a job to day and some one had 2 m added on to a washing machine so the flex was about 3 m long
personaly i would have fitted a socket closer to the appliance
its not in the regs...
grab a copy of the PAT testing booklet by the IEE its in there... i dont have a copy to hand but i belive you can have any thing up to 12m..... see if i can find a copy at work!!
Im not aware of any regulations regarding the lengths of flexible cords on fixed appliances, however I would rather see a new cord fitted as opposed to extending the existing one
In service.......Code of practice is a bit vague, states taped joints are unnaceptable and earth must be continuous and must not exceed the length allowed by the equipment standard.....WTH
So basically I cannot see its a major problem if its done properly!
Definition of PA
An appliance of less than 18kg in mass that is intended to be moved whilst in operation or an appliance which can easily be moved from one place to another, e.g. vacuum cleaner, toaster, food mixer, etc.
A washing machine is deemed as Stationary equipment or appliances don't know if that means anything to you.
Reply to length off flex you can ad to an appliance in the Australia area at ElectriciansForums.net
Part III:). I think I have clarity-having spoken to my electrician who installed my heaters, he said that the part of my fuseboard that is...
2 3 4
By retired electrician, I mean that I have retained my ticket but no longer do installation work. Thanks for the clarification. I missed that it...
