Lengthening a vacuum power cable
Hi all I am new to the forum and am looking for some advice on the legality and best way to increase the length of a vacuum cleaner power cable without using extension cables.
It is in a nursing home environment.
Can I just replace the cable myself or do I have to have an electrician do it?? Is it legal to add a female to Male plug making a longer fly lead??
Many thanks
Many thanks
The establishment I work at, trailing leads are not used on the care floor. Cordless vacuums are used. Outside of that, only the manufacturers leads are used on ordinary corded ones.
What’s the issue with an extension lead ??
Many thanks
There are many things to consider.
Is replacing the existing lead with a longer one worth the cost?
The longer lead will be more prone to damage, simply because there will be more of it.
If the longer lead is damaged, then it will cost more to replace.
The longer lead may require having larger conductors due to volt drop.
What would you do with the longer lead, if the hoover stops working?
An extension lead (even with larger size conductors) may be cheaper than the length of cable you need to replace the hover lead.
If either the hoover lead or the extension become damaged, replacement would be cheaper.
If the hoover needs replacing, you would still have the extension lead.
One drawback with an extension lead, is that it should in most cases be fully unwound when used.
Another draw back, is that there are more plugs and a socket which could be damaged.
Another is someone may borrow or steal the extension lead.
I would tend to think of using an inline mains connector plug and socket to replace the existing plug, however this is effectively an extension lead.
Generally it is not easy to replace the entire cable as the internal connections in the vacuum cleaner are not readily accessible and may not be removable.
If thats in response to my post?
Care floors are populated with elderly frail residents, who predominately shuffle their feet along the floor when moving about. Hence trailing leads are a serious trip hazard, however careful the user might be.
Thanks for the advice guys lots of information I think will use an in line connection where the plug used to be. Its because the new purchasing office has bought a couple of domestic hoovers and the cables are only 10 feet long!!! Silly Billy's paid cash so can't be returned!! Smacks a bit of someone not really able to do the job they have been brought in to do!!
a 10ft. lead on a vac? bloody stupid. unless half of it is stuck in the spring loaded retractor mechanism.
Its daft having a lead that short!! And it's not a retractable one either! Am starting to feel that there is something not quite right about the machines ie dodgy/knock off!!
just had a quick look at our Henry and Kirby. both have flexes in excess of 20 ft.. enough to hang the missus and still be able to clean up the mess. :eek::eek::eek:.
Adeyboit,
Adeyboit,
