F
Foxhound
Hello again,
Sorry to ask again but I've got a fault I need to find an answer to finish off my assignment and despite my best efforts I've been unable to find much information about it.
Lighting 2 -
A two-way lighting circuit installed for 5 years has both two - way lighting switches changed for dimmers and the LIGHTS start pulsating? Need to write the fault out and the how to rectify it.
I'm not working in the field at the moment so be gentle but I just haven't been able to find much for this fault. All I know is that you can only have one dimmer on a two way lighting circuit because of the alternating current and because of the bulbs using thyristors that are trigged relative to the zero crossings of the AC power determines the power level. By changing the phase at which you trigger the triac you change the duty cycle and therefore the brightness and therefore the brightness of the light.
I'm getting a bit confused here how all this comes together to affect the light to make it pulse. I'm assuming that both dimmers are competing with each other and they reacting to the alternating current making the lights pulse.
Any help here to clarify this i would much appreciate it, only my tutor is a bit ---- retentive.
Thanks for your help again (I not its a home work site!!)
Lighting 2 -
