Guest viewing limit reached
Hi everyone my question is does can anyone one give me a wiring diagram for the Leviton 1388-1 dpdt switch that shows one 220 volt input to run 2 separate loads the switch has 6 connection points any help will be greatly appreciated Ton
I am sorry to say, the instructions and wiring diagram are posted above, if you cant figure out what they are showing then i suggest you find a local electrician to sort it out.
it is not a complicated requirement and it should not cost the earth, but you will know that it has been done correctly.
Hi James thank you for your response - I understand the wiring that’s no problem - I was just concerned that the diagram showed 2 hot lines from different voltage source and i wanted to be sure that l1 and l2 can be the one power source of220 vac ( each 110 volt lines) but I kind of figured it out
NY
United States of America
If other, please explain
DIY er
Leviton dpdt 1299-1 switch
Bulldog,
Bulldog,
