R
rantoftheday
Got to get beneath a tongue n groove floor for to access under floor running a cable to a shower
whats the best way to do this?
Discuss Lifting Tongue n groove in the Australia area at ElectriciansForums.net
Yep, doesn't seem to be any hard/fast rule for it, but forewarned is forearmed (or something like that)Sometimes TQ but what we often find is that there is ...about a 3" gap between the wall and the edge of the joist which allows you to "wriggle" the board free.....as above a circular saw or a fein....what i do is use thr fein to cut across the board on a joist (therfore doing away with needing a bearer) and to use the circular saw (remembering to set the depth so as to avoid the plumbers pipes he`s sure to have left in your way) then when you cant get the saw any nearer the skirting board (due to the sole plate)....just finish the cut with the fein. I try to avoid using the fein apart from where absolutely necessary as the blades are hellish dear.....
Depends on the span between joists and the thickness of the board.....those 1" thick ones in victorian houses are pretty tough........I use a nail puller and a multi tool.
Remove the nails from 2 boards first, cut the tongue from either side of these boards then cut across the joist at whatever length you need.
I always take 2 boards out cos 1 board with no support on both edges will bounce.
That sounds good, how do you use the nail puller without making mincemeat of the floor board around the nail?I use a nail puller and a multi tool.
Talking of forearms....seemed to have pulled a muscle in my left arm banging in backboxes into engineering brick yesterday.....couldn`t even handle the snips right today....soft git...lol.....:whatchutalkingaboutYep, doesn't seem to be any hard/fast rule for it, but forewarned is forearmed (or something like that)
This one was out at guiseley though Phil.....still rock hard though....ohh....if all houses were just thermalite inside..lol....One of my mothers houses in shrewsbury has these bricks inside called ruabon brick . Ruabon is a small town in north wales and the bricks they make there are fired at a very high tempreture so they are super hard............:yesnod:those houses in cass are rock hard. my hands hurt for a fortnight after chopping one of those out
Reply to Lifting Tongue n groove in the Australia area at ElectriciansForums.net
