Light bulbs regularly blowing | Page 2 | on ElectriciansForums
Discuss Light bulbs regularly blowing in the UK Electrical Forum area at ElectriciansForums.net
South east
Evening all, got a customer who is complaining that her light bulbs across the house keep blowing, and could I come and have a look at it. Short of stripping the circuit down and testing it, ensuring all connections are tight etc, can anyone suggest what might be the problem. She did tell me that she had been buying the bulbs from Wilko's, so I suggested buying some from a more reputable brand and see how they go.
Any thoughts?
1) Over-voltage / spikes on cheaper lamps
2) Loose conductor causing spikes (prob neutral)
3) Cheap lamps, full stop
4) Maths and the law of averages - as in, if I have one lamp in a room it's going to fail 1 in H hours but if I have eight lamps in a room then my 'apparent' failure rate is 1 in H/8, so a much bigger chance of finding a lamp out at any instance in time (although it's not the same lamp, but Mrs Jones rarely remembers that!)
If it's consistently the same fitting then you've got a loose connection (remember to check at the switch as well!)
My experience with blowing lamps is as rockingit mentioned, but to add sometimes the lamp holder on the ceiling roses actually widen and the heat on the bayonet makes the lamp move about and short out the lamp
Why neutral especially? I can understand our American contributors finding this a more likely cause, with domestic split phase supplies where a neutral loss in the DB can cause 240V to appear across 120V circuits. But in an SP+N situation, I'm curious about the mechanism that would make a difference between L & N. Or do you mean they are more often found in the N, for some non-electrical reason?
I've also realised the OP doesn't say what kind of bulbalamps are blowing, whether they are tungsten, halogen, CFL...
No technical issue that I know of, just that in my experience it always seems to be neutrals that come out of screw terminals for come reason.
Reply to Light bulbs regularly blowing in the UK Electrical Forum area at ElectriciansForums.net
Thanks for you response, that makes more sense LEDs do produce less heat. I think i read somewhere that LEDs are more sensitive to heat, as in...
Check the clearance between the back panel and/or terminal cover that you've removed. Look for small burn marks.
