i don't have much domestic experience as i have worked largely in shops and pubs during refurbs.
I have a potential job lined up i want to use for the NICEIC assessment.
The customer wants a new consumer unit. The current one also has holes in the side from old cables and is barely hanging onto the cupboard wall. having looked at the set up all the lights (both floors ) are on one circuit..
With a little bit of investigation i found the reason for this is a shared neutral on the 2 way landing lights. when the current CU was put in the person who did it took both lighting circuits and put them on the one breaker. Most likely to stop the inevitable tripping the shared neutral would cause on a newish board.
The problem i have is the old lady whose house this is in, has recently had it decorated and is immaculate.. there is no way she will let me correct any problem cable runs in walls. there is no way to pull cables as they are plastered in with no conduit or trunking. likewise the attic area is all boarded out and is a room for the grand kids to play in.
I was always led to believe that with a split load board you should ideally put upstairs and downstairs lights on separate sides of board. so that if one trips the other floor still has lighting.
Is there a specific reg that says both light circuits can not be on the same circuit, i can not find one that clearly prohibits it, but neither can i find one that expressly permits it.
Any thoughts or ideas on how to handle this?
How common is this in UK homes?
When installing the new CU can i put both light circuits on the one breaker covered by one RCD? Or am i obliged to sort out the issue with shared neutrals so i can separate them out.
Any advice would be much appreciated.
