Light flashes then dies | on ElectriciansForums
Discuss Light flashes then dies in the UK Electrical Forum area at ElectriciansForums.net
DimGlowWorm
I have two security lights outside with a motion sensor. Up to a few weeks ago they worked okay but now I switch on, there is a flash from both lights and they both go off. They haven't tripped the circuit breaker but switching on again produces nothing. However, if I leave it an hour or so, then switch on again there is another flash of light and then nothing. I have replaced one bulb but all connections look okay. Is there a simple solution or do I need an electrician?
Is it a stand alone pir detector?
if so then that's your problem, get another one. I'd suggest you phone a local,sparky to install it though !!
There's just one pir detector with two outside lights. But it was working fine upto a month ago - I was just hoping there might be an easy fix I could do myself. Thanks for the advice, anyway. :hurray: Looks like I'll have to call in the Professionals!
Reply to Light flashes then dies in the UK Electrical Forum area at ElectriciansForums.net
Also posted in DIY. strange one in my kitchen. 3 sets of 2-way switched mains GU10 Philips down lighters. ( no dimmers) Have been fine for...
It does seem to me that there's a capacitively coupled voltage to each set of downlights (on the light side of the switch), and when you put the...
