Light interfering with door entry. | Page 2 | on ElectriciansForums
Discuss Light interfering with door entry. in the UK Electrical Forum area at ElectriciansForums.net
Simonslimline
South West, Bath
I live in a flat which has a buzzer to let people in. Recently I noticed than when i turned the buzzer to privacy later it would have turned back on gain by itself.
I changed my bathroom light a while back from a "4 pin 16watt 2D fitting" with a smaller style 2 pin 16watt fitting due to the old one stopping working.
I have noticed that when I switch the bathroom light off that the buzzers red privacy light switches off and the buzzer is back on again.
What might be causing this to happen! Any guidance on this would be much appreciated.
I would try another light fitting myself , if you have a temporary batten holder or something try that, if its o/k then replace the light fitting , if you can't find the logic behind it ,
some things are jut unexplainable ,,,,
Reply to Light interfering with door entry. in the UK Electrical Forum area at ElectriciansForums.net
My guess is an earth to N fault in the damaged light fitting. This will become a problem when other devices draw large currents.
M
Low pressure light coming on. My Ariston Eurocombi A23 low pressure light has started to come on. When the kitchen HW tap is on the boiler...
Merton69
M
