light keeps going out | Page 2 | on ElectriciansForums
Discuss light keeps going out in the UK Electrical Forum area at ElectriciansForums.net
Rotherham
Hi there,
I'm looking for advice about a problem I keep having in my bungalow. The light in my bedroom keeps failing. It happened last year, the electrician put it right but it's happened again so I think there may be an issue that the electrician missed. I'd like to ask if anybody has any ideas what the problem may be before I call an electrician again.
Last year, the light was initially switching on OK, then, after 10 minutes or so, it started going out for a few seconds, then coming back on for a few seconds, then out, on, out, on... I changed the bulb, the same happened. The electrician came. He said it was the bulb despite it being new. He changed the bulb again, and the light worked well for a year or so, until now...
Then, a few days ago, I could no longer switch the light on. As I pulled the switch, I got a very brief flicker of light and then it went out immediately. I have changed the bulb. The same problem kept happening. Now, the switch doesn't have any effect: the light does not come on at all.
So, has anybody got any idea of what is happening? Is there something I should look for or be aware of before calling an electrician?
None of the other electrical items in the bungalow is causing a problem. I have had solar panels installed between the two series of incidents - in case this could be relevant -.
Any ideas?
Sounds like a loose connection at either the switch, the rose or the lamp holder.
Although it is possible the contacts inside the switch or the lamp holder have become tarnished, or even the spring inside the pull switch has broken.
I agree, I had exactly this problem this week, same symptoms. A pull cord switch, with a loose connection. Simple fix, happy customer
I wouldn't use his finger, don't know where it's been!
Stick with the screwdriver.
I'd press them in with the tip of an insulated screwdriver not your finger, well maybe your finger but not mine. :p
I'd use something blunt rather than the tip of a screw driver, the tip tends to slip off the pins. Especially if your hand is not as steady as it used to be like mine. ;)
Hi there,
Any ideas?
Hi there,
Any ideas?
Hi there,
Any ideas?
Obviously a loose connection at the fitting
Problem solved! I hired a different electrician. He first checked the ceiling rose and pendant but didn't find anything. He then checked the pull switch and found that a small round brass part in there had come unstuck, so contact wasn't always made. He fitted a new switch. My light is now working neatly: a pull of the cord turns it on straight away, another pull turns it off. :)
Reply to light keeps going out in the UK Electrical Forum area at ElectriciansForums.net
You as well! Popcorn and beer on hand plus a day off, I'm ready! :)
My guess is an earth to N fault in the damaged light fitting. This will become a problem when other devices draw large currents.
