Feb 14, 2021
34
London
United Kingdom
Hello everybody! Just a quick question, is it good practice to have light switch above radiator? Please see picture attached. Wall is quite small, and in the same wall is radiator going, is it acceptable to have switch where is marked as 350mm from wall corner or should it be moved to the left side? I am not sure what is regs are for switches above rads, as i cant find anything.
Thank you for your help.
It will be fine.
So does not need to be moved anywhere then? The reason i am asking is i havent seen switch above rad to be honest :)
Is the cable going up or down?
3 core cable going from downstairs, and ceiling rose going from top
Let’s hope whoever is hanging the radiator understands electrician’s safe zones.
Look how many TVs are wall mounted above radiators, or even on chimney breasts with a gas or electric fire below.
A switch will be fine.
Thank you for reply guys, last question: what is the distance from door frame to the switch? Or how far switch is located from door frame? Some electricians saying its 150mm or 350mm as per regs? There must be some sort of standarts thats every one sticks to. Please advice guys. Thank you
Doesn't matter.
Reactions: DPG
It would look better if it’s the same distance from the doorframe (and height) as other switches in the house…
  • Agree
Reactions: Simon47 and DPG
Far enough away that it doesn't get in the way of the architrave being fitted.
And preferably the same for every door in the property
what if a cable is going behind a pipe, but its in conduit and plastered over? should be fine right
What's your opinion on this other scenario?
London
United Kingdom
Light switch above radiator
Domestic Electrician Forum
DJ12345,
baza890,
