Light switch over stairs | on ElectriciansForums
Discuss Light switch over stairs in the UK Electrical Forum area at ElectriciansForums.net
B
Ben Grant
I have been asked by a customer who doesnt want a ceiling switch in a bathroom to move the exisiting plate switch to the other side of the wall - about a 5 min job. however this will put the plate switch for the bathroom above the second step on the stairs going downstairs. It doesnt come out to the landing but instead above the stairs as it begins to drop to the ground floor. I have said i cant put it there as its above the stairs, but the local council have said to do so and i want to know if there needs to be a clearance from the top of the stairs to any accessories like switches, sockets ect. I have never put them above the stairs, need to know if there is an solid YES or NO to positioning a light switch so close to the fall of the top of the stairs. also the Reg if one exists
cheers for the help!
Are you saying the existing plate switch is in the bathroom? If so then I would definitely move it - not a good idea in a bathroom. Why on earth does the householder not want a pull switch?? That's what everyone else does! Daz
Or bedroom, outside, living room, dining room,
Or just in bathroom on pull cord or by bathroom door but not over stairs, or over stairs it's not switching landing lights on/of is it and you will not trip up on it
You'll never guess where my bathroom light switch is ...........
............ Outside the bathroom ..............
.......... It's one gang of a two gangswitch ...........
.......... and it's above the first step down of the staircase. :blush5:
that's good for a geordie. i'd have expected a pressure mat to save the effort of pressing the switch.
Reply to Light switch over stairs in the UK Electrical Forum area at ElectriciansForums.net
As above you will probably find the originals where oriented the same way and your replacements are upside down to each other, or visa versa. I...
Take it off, pull the cables through the new board and refit light once plastered.
