Light switch problems | Page 3 | on ElectriciansForums
Discuss Light switch problems in the UK Electrical Forum area at ElectriciansForums.net
L
lofty84
Ok my next stupid question that I should no but I dont is this
I have a lounge with one pendant fitting in the middle, at either end of the room where you enter from the hall and enter into the kitchen there is a switch. I took of the original switches which were crome and wired in the standard plastic ones as per my instructions I did this in exactly the same way that they were before i took them out. the problem I have is that if I turn on the light from the switch you come across when entering the lounge the light comes on but if I walk over to the switch you come across when you enter the kitchen and then flick this switch to turn it of the light stays on. If I go back to the switch by the entrance to the lounge and flick the switch again it turns of. if i then walk back over to the switch by the entrance to the kitchen and switch it on the light turns on but again will only turn of by the switch that I used to turn it on, in this case the one by the entrance to the kitchen. clearly Ive wired it in wrong, yes I am a idiot because I dont know how to rectify this and yes im cheating by asking you guys but as I say I dont really want to loose my job.
Im going to have a go at working it out but in the meantime here are the pictures of the switches in question I dont think there that clear but some of the brighter sparks might be able to see whats going on and help me out a little..... fingers crossed
This is the switch by the kitchen door
and this is the one by the entrance to the lounge
[ElectriciansForums.net] Light switch problems
I drew these at the weekend maybee i should take em with me
  • [ElectriciansForums.net] Light switch problems
Reply to Light switch problems in the UK Electrical Forum area at ElectriciansForums.net
As above you will probably find the originals where oriented the same way and your replacements are upside down to each other, or visa versa. I...
