Light switch question. | on ElectriciansForums
Discuss Light switch question. in the Lighting Forum area at ElectriciansForums.net
Lachute, Québec
Hi There, not certain if I'm in the right place but here I go ! I have 4 LED ceiling (4 X 9 watts, 110 V AC) lights that are currently working on a 3 way regular 3 pole switche configuration. I want to make a change by installing push button switches on a plaque that will be installed on the bed's backboard. I'm not able to find a 3 way push button switches. My question is, is it possible to wire up qty 2, 2 pole switches in a way to make them work as a 3 way switch. If so how to I connect them together? Thanks.
Have you looked at a grid type of Qlik?
I don't think you mean '3-pole' switch. There are 3-pole switches but they are not the same as 3-way, and are not needed to control a light from two locations. A 3-way light switch is a changeover switch with three connections, that switches the common connection from one of the two traveler wires to the other.
Is this anything like what you are looking for?
Hi, thanks for your input I've already found what I'm looking for. Have a very merry Christmas1
Reply to Light switch question. in the Lighting Forum area at ElectriciansForums.net
    • Friendly
Yes I understand the setup now. Sorry about my confusing first post 🫢 It might be worth buying the Livolo switches you identified and lash at...
brilliant thanks for your support. Lee
