Light switch wiring query | Page 3 | on ElectriciansForums
Guest viewing is limited
Discuss Light switch wiring query in the UK Electrical Forum area at ElectriciansForums.net
Enfield
hi. I went to put a new light switch in my porch that controls the light in there and the front door security light and when I took the old switch off the wall I found what you can see on the picture attached. Can someone explain why it is wired up like this?
[ElectriciansForums.net] Light switch wiring query
Is it the term they use for borrowed neutrals
As well as the two way concern, in a case of properties, many borrowed neutrals occurred when the original CU had only one lighting circuit. A new mcb CU and the circuit being split into two, upstairs and down, resulting in a common neutral. Just bad practice.
Reply to Light switch wiring query in the UK Electrical Forum area at ElectriciansForums.net
Thank you so much for your help with this light work perfect now thank you again much appreciated
Thanks again for your help, now solved 👍
Recommended Sponsor News
Hi everyone,
Enfield
