View the thread, titled "Light switch with overrun timer..." which is posted in Electrical Tools and Products on Electricians Forums.
I went to swap a fan for a customer, they wanted a humidistat one. When I dropped the old fan I found it was wired with T&E.
I explained there was no permanent live so no overrun was possible, and that I'd either have to make a lot of mess running a three-core or they'd be best off leaving the light on after using the shower, they said to put it back for now.
Then I thought, could the switch act as the overrun timer leaving the live live after switching off for a period of time? I've looked on live and can only see the push button on for a certain time switches, for hallway lights etc.
You'd probably want two switches, one to isolate the supply to the the timer switch and hence the light (and FIS), the other to be the timer switch.
Does anyone know is a switch like that exists?
where does the fans t&e come from? The switch, the light or a joint box above?
You could put in a second switch for fan, or a timer module or occupancy sensor where you have a live and neutral.
Four cables in the switch, all neutrals in a connector, so feed in, feed out, 2 Sw/L's 1 going to the light, one to the FIL, I assume.
I could move the Sw/l to the FIS to the perm live side of the light switch.
Don't suppose you have a link to an example of a timer module?
And would a sensor have a built-in overrun?
I've not used one before, could you share a link please?
Example: Bathroom Fan Delay-Off Timer Switch Socket 100W - https://crwltd.co.uk/bathroom-fan-delay-off-timer-switch-socket-100w-3096-p.asp?
It might be a squeeze to get the above in the back box if that's already full of wires1
Manrose do switch-plate size one which you'd have to mount next to the light switch but it's £30 ish
Reply to the thread, titled "Light switch with overrun timer..." which is posted in Electrical Tools and Products on Electricians Forums.
