light switches in bathrooms - | Page 2 | on ElectriciansForums
Discuss light switches in bathrooms - in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Just come accross a new job, part p elec has fitted standard plateswitch and 2 fused spurs in a bathroom that gets very steamy with a tiled floor, having spent 26 years in the industry, on re wires/new wiring, im not as yet part p, i was appaled, I would have fitted pull cord, or all switches outdide bathroom door, where its wood flooring, dry and carpeted, they call it progeress?
The Americans have twin socket outlets in all there bathrooms, but they are 115 volt and are always the integral protected type with a 6 mA RCD. They tend to use normal wall switches too (not IP rated in any way), like most other countries throughout the world. That's not to say that the higher UK standard for bathrooms should be lowered to match other countries standards, quite the opposite!! Mind you, i do find the 17th BS7671 regulations go a little OTT. Earlier regulations were more than sufficient, as proved by 30 odd years they were in use...
and adolph hitler was not a megalomaniac, power mad dictator. he was a misunderstood and humanitarianly disadvantaged.
Reply to light switches in bathrooms - in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I was considering that, however the loft isn't boarded, not exactly the lightest 🤣 I was hoping I wouldn't have to do that but maybe that's the...
Thank you, both. Seems like common sense may have prevailed, and the fellow is indeed going for one of the modern mirrors you mentioned...
