Lighting advice for a flat | on ElectriciansForums
Discuss Lighting advice for a flat in the UK Electrical Forum area at ElectriciansForums.net
Hi all,
Been a while since I have posted on here, I'm looking for some advice on the best lighting for a small kitchen in a flat, the kitchen has no windows and currently has a woefully inadequate 4 lights in 1 unit set up. Unfortunately the ceiling is concrete so I can't put spots in. Also what are the regs for lights above a kitchen sink apart from common sense and not putting them too close.
Any help gratefully received.
D2E
Have never actually seen a light above a kitchen sink anywhere to be honest, is that a request from the client? Depending on how low these ceilings are and how hot the water is going to be, not sure they would be too happy you sticking a vapour proof flour above the sink. Rethink the fitting above the sink.
There are loads of modern fixtures you can recommend and have a chat with the client and see what they want. Again depending on ceiling height and budget you could put a false ceiling in. You can get PVC ceilings that are used in Kitchens/Bathrooms that allow you to even put the dreaded downlighters in
I think the light above the sink would only be OK if it were on the ceiling or close to it (assuming the ceiling is normal height), however I do not think there are any specific regulations, only the suitable for the environment requirement.
If it is just a small kitchen you could perhaps run LED strips along the ceiling (probably the waterproof ones) to illuminate the work areas with the driver above the kitchen cabinets. However it would have to suit the occupiers sensibilities.
In a kitchen you just need to light the work surfaces, including the sink and hob, so in a small space you could do the whole lot with under-cabinet (or more specifically 'over-worktop') fittings. As long as you can see what you're doing everything else is just 'fill'.
Hi,
You'll probably laugh at this. I did a flat for someone a while ago, they didn't want downlighters or anything like that; so i put in a decorative twin tube fluorescent ( Thorn I think ). Looks OK, gives good illumination to cupboards, work surfaces and floor. may be a bit old fashioned now but certainly worked in this case. Sometimes the simple approach is the best.
Regards.
Hi,
Regards.
Done the same in the past.:D
Reply to Lighting advice for a flat in the UK Electrical Forum area at ElectriciansForums.net
SOLVED Thanks for all the help. It was nothing to do with the smoke detector. In this new hole (where there will be a light fitting) three white...
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
6K
