Lighting advice for a flat | Page 2 | on ElectriciansForums
Discuss Lighting advice for a flat in the UK Electrical Forum area at ElectriciansForums.net
Hi all,
Been a while since I have posted on here, I'm looking for some advice on the best lighting for a small kitchen in a flat, the kitchen has no windows and currently has a woefully inadequate 4 lights in 1 unit set up. Unfortunately the ceiling is concrete so I can't put spots in. Also what are the regs for lights above a kitchen sink apart from common sense and not putting them too close.
Any help gratefully received.
D2E
What's wrong with a good quality head torch, light wherever you go
Have never actually seen a light above a kitchen sink anywhere to be honest, is that a request from the client? Depending on how low these ceilings are and how hot the water is going to be, not sure they would be too happy you sticking a vapour proof flour above the sink. Rethink the fitting above the sink.
There are loads of modern fixtures you can recommend and have a chat with the client and see what they want. Again depending on ceiling height and budget you could put a false ceiling in. You can get PVC ceilings that are used in Kitchens/Bathrooms that allow you to even put the dreaded downlighters in
good thinking /track lts/false ceiling
Reply to Lighting advice for a flat in the UK Electrical Forum area at ElectriciansForums.net
SOLVED Thanks for all the help. It was nothing to do with the smoke detector. In this new hole (where there will be a light fitting) three white...
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
6K
  • [DIAL] What Is The Cancellation Policy For Expedia?
    π”Όπ•©π•‘π•–π••π•šπ•’ 𝕠𝕗𝕗𝕖𝕣𝕀 𝕒 π•˜π•–π•Ÿπ•–π•£π•’π• 𝟀𝟦-𝕙𝕠𝕦𝕣 π•”π•’π•Ÿπ•”π•–π•π•π•’π•₯π•šπ• π•Ÿ π•‘π• π•π•šπ•”π•ͺ. π•‹π•™π•šπ•€ π•žπ•–π•’π•Ÿπ•€ π•ͺ𝕠𝕦 π•”π•’π•Ÿ π•”π•’π•Ÿπ•”π•–π• π•žπ• π•€π•₯...
  • Song words.
    All I Wanna Do Is Make Love To You View: https://www.youtube.com/watch?v=OAfxs0IDeMs
  • What is the refundable option on 𝔼xpedia? Cancellation Policy
    What is the cancellation policy for 𝔼xpedia? π”Όπ•©π•‘π•–π••π•šπ•’ 𝕠𝕗𝕗𝕖𝕣𝕀 𝕒 π•˜π•–π•Ÿπ•–π•£π•’π• 𝟀𝟦-𝕙𝕠𝕦𝕣 π•”π•’π•Ÿπ•”π•–π•π•π•’π•₯π•šπ• π•Ÿ...
