Doomchild
Hi all,
last week I decided to start painting the inside of the house and began in the kitchen. So to paint the ceiling, I lowered all LED downlights and left them prised using the spring loaded mechanism allowing to paint under the gimbals, so no weight was placed on the wiring whatsoever.
After paining and re-fitting the lights as previously done, the downlights no longer come on and on checking the voltage at both switches and receptacles the voltage is now 138V instead of the expected 240V.
All other lighting is working fine so we are having to cook by candle light - LOL.
Have checked:
NB. LED lights are 240v so no tranformers are being used.
Any help is much appreciated.
Cheers.
Have checked:
- All wiring in the roof and all seems to be ok - physically that is.
- Junction boxes with NFF.
- Switches ok with some been replaced as a precaution
- Cct breaker supply is at 240v,but for some reason it is lost to what appears to be high resistance but if it is the case I have been unable to find it. It would also appear that this may be a case of a floating neutral, but again I am not sure where to begin as I cannot determine mid-way so I can troubleshoot one half and then break it down further.
Cheers.
