Lighting circuit - no CPC | on ElectriciansForums
Discuss Lighting circuit - no CPC in the UK Electrical Forum area at ElectriciansForums.net
smity
Alrite lads,
I'm a commercial spark so don't do much domestic but a mate of mine asked me to Pop round and change a light fitting in his kitchen 5 min job, he had an old 6ft fluorescent which was shot and he has brought a new class 1 fitting.
I remove the fitting and there's no CPC so I checked at the old wylex board and the downstairs lighting has no CPC at all and there's also no RCD present so this is now more than a 5 min job.
I have told him to get a class 2 fitting for the kitchen and advised an RCD/New board but I also think he has some other class 1 fittings which are potentially dangerous (wall lights etc)
So other than remove the class 1 fittings or rewire the circuit is there anything else that can be done?
Thanks, Yeah though that but thought I would check incase there was anything else.
Where do I stand on swapping kitchen fitting for class 2 then advising on the remaining work that needs doing if he doesn't have it done? I won't be leaving the circuit more dangerous than it is but not happy that it's potentially dangerous.
And technically I can't change the CU for him as I'm not part p :-(
Just another little point,how old is the property? What type of cables are used? I have visited several built in the 60's that were wired in t&e,but had the CPC cut back at every fitting. Cables in good order,IR fine,just required diggin' and extendin' ...
What a load of genitalia, course you can change a CU Part P is a building reg, no one can be part P
Now that's a novelty!
What's next - pigs with wings???
no wings, i'm afraid... next best thing though....
[ElectriciansForums.net] Lighting circuit - no CPC
Reply to Lighting circuit - no CPC in the UK Electrical Forum area at ElectriciansForums.net
When you did the further testing and got the 0.06 reading were the CPC's back in the consumer unit? Really when testing you should leave the...
none at all.... and the rcd trips within specification... test button operational.... nothing to suggest there's a problem until you take the...
