lighting circuit required urgently | Page 3 | on ElectriciansForums
Guest viewing is limited
Discuss lighting circuit required urgently in the UK Electrical Forum area at ElectriciansForums.net
G
GLYNN
Hi
Is there any one out there n sparky world can draw me a wiring diagram for the following. You can see the drawing that n entering the main door top of the stairs, on the left will be two double switches one will be able to turn on the main light, with the option to be able to turn on/off from the bedside as well. The other double switch again to be able to turn on/off the beside lighting.
I hope someone can help?
  • [ElectriciansForums.net] lighting circuit required urgently
I am a electrical panel engineer so me doing the work is not an issue all want is a simple diagram of how to run the wiring, and I want to be able to turn the lights on and of fro the bedside, as my brother is now bed ridden following drunk driver hitting him, leaving him unable to ever walk. This way he can control the room lighting. So "it is nothing kinky" as some has said?
Hi Glynn the oil or infact the 710 dimension at each side of the bed is where the "kinky" comes from 710 upside down as in the drawing is OIL.
My son had a similar accident and was in intensive care over 12 week followed by another 6 month in hospital he is lucky as regained some use of his legs and now can walk short distances so have an idea what you are going through and wish you all well.
here is a clear diagram showing 3 way switching hope it helps
Reply to lighting circuit required urgently in the UK Electrical Forum area at ElectriciansForums.net
My guess is an earth to N fault in the damaged light fitting. This will become a problem when other devices draw large currents.
Recommended Sponsor News
Hi everyone,
