Lighting circuit with no CPC, fail??? | Page 3 | on ElectriciansForums
Discuss Lighting circuit with no CPC, fail??? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
You'll probably find that the conduit has been used as an earth. If the loop test is satisfactory and there is no obvious degradation (which I doubt) then the installation must only be as good as the regs, probably 13th or14th, defined at the time of installation. I think a good visual inspection will prove that this installation needs rewiring, put away your instruments and use your common sense.
the op has already said there was no conduit being used as cpc.
Reply to Lighting circuit with no CPC, fail??? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
It’s difficult to advise on an electrical issue when some isn’t very conversant with electrical terminology.
