Guest viewing is limited
View the thread, titled "lighting circuit" which is posted in Australia on Electricians Forums.
how do, can anyone tell me about a lighting circuit that has neutrals in a terminal block at the light switch?
how does it work and how would you add to it?
thanks
howdy do back
this is just like three plating a ceiling rose but you just do it at the switch so you only have one t+e at the rose, easier for connecting downlighters etc, less wires. so you would have at the switch, in t+e anyways -
a feed in (t+e)
a feed out (t+e)
and a switch line (t+e that goes to the rose)
so you put all your neutrals in the connector, all your earths together, then the feed in and feed out lives in one half of the switch and the switch line out to the rose on the other half.
to add to this from the switch you would connect to the neutrals, connect to the earths then connect to the feed in feed out side of the lives. this would give you L N E to take where you wish a spur.
hope this helps
If you have neutrals in a terminal block in the lightswitch sounds like the switch is on the live terminals which is where it should be and the neutral is coming from the CU via the switch to the light. The terminal block has been used to complete the circuit.
More investigation by you is needed to confirm this and what do you want to add
Chris
Reply to the thread, titled "lighting circuit" which is posted in Australia on Electricians Forums.
