lighting circuits - just for lights???? | on ElectriciansForums
Discuss lighting circuits - just for lights???? in the UK Electrical Forum area at ElectriciansForums.net
jedisparks
On a domestic lighting circuit it is not uncommon to find an extractor fan, shaver point sometimes a smoke alarm or even a doorbell transformer. Just wondered what peoples' views on this is. It's the norm for extractors and shavers I know, but they are not lights so should the CU be labelled accordingly? How about if a smoke alarm is connected to a lighting circuit or door bell transformer? Where do you draw the line and at what point is it not acceptable to connect an item of current using equipment to a lighting circuit that isn't actually a light? What has provoked this question is that a client has asked me to power a wireless heating controller via the live and neutral supply from a local light switch. It's a Honeywell evo home system, so the controller doesn't switch any loads as such, just sends and receives signals. I'm not keen on the idea, but how can I justify a possible refusal to do it - if other non-lighting products are connected. He is pretty savvy, so need decent justification without looking like a knob lol!!
Nothing wrong with equipment other than lights on a lighting circuit as long as all regs are met ie overloads and disconnection times. If you are bothered that much by it you can get an 'installation notes' sticker for the c/u and you can leave comments on it such as 'heating switch powered by downstairs light circuit'
sounds like you dont need money to keep a business going , do what he asks nothing wrong with it , even leave a note at db saying its attached to lighting circuit in what room at what height etc etc :O
I would say check the total loads on the circuit if there not exceeding maximum capacity fine. Also agree with above comment place sticker on c/u to identify whats on the circuit you are adding to.
Reply to lighting circuits - just for lights???? in the UK Electrical Forum area at ElectriciansForums.net
Anywhere where the normal lights are dimmed or dimmable the emergency lighting should be of the maintained type. So maintained emergency lighting...
davesparks
