On a domestic lighting circuit it is not uncommon to find an extractor fan, shaver point sometimes a smoke alarm or even a doorbell transformer. Just wondered what peoples' views on this is. It's the norm for extractors and shavers I know, but they are not lights so should the CU be labelled accordingly? How about if a smoke alarm is connected to a lighting circuit or door bell transformer? Where do you draw the line and at what point is it not acceptable to connect an item of current using equipment to a lighting circuit that isn't actually a light? What has provoked this question is that a client has asked me to power a wireless heating controller via the live and neutral supply from a local light switch. It's a Honeywell evo home system, so the controller doesn't switch any loads as such, just sends and receives signals. I'm not keen on the idea, but how can I justify a possible refusal to do it - if other non-lighting products are connected. He is pretty savvy, so need decent justification without looking like a knob lol!!
Why dont you want to do it? What's the alternative? Pull a new radial through for one item that doesn't even draw anything? If you tell your customer that he might refuse the job for you :D
No, My idea would be to have a fused spur off of the ring. but this would be a bit more work as the client ideally wants the unit just below the light switch. Hence why I thought some views from others might be useful. I haven't refused to do anything either, it's just a job that is coming up. Thanks for your input
OMG you would actually spur from a ring to feed something that doesnt need to plug into a socket
and would be on the relevant circuit
This would be ideal except it's 20ft away from where they want it. This Honeywell evo home kit is quite new, what you get is a controller that goes in say the living room from where you can control every single radiator separately, as each radiator has an RF thermostatic valve. The controller also controls a relay, again RF, which is what switches the boiler via the zone valves. The controller comes with a plug in lead but the units can be wall mounted and we want to make it tidy. The idea is that the controller doesn't go where the boiler is.
After you have done the job change the label on the cu to
"Honeywell evo home system and lights"
then it will be a
Honeywell evo home system circuit.
lighting circuits - just for lights????
jedisparks,
Stroppy,
