I am somewhat confused as to why an upstairs landing light does not work unless the switch in the hall downstairs is switched to the off position. it defeats the object of turning it on downstairs and switching it off upstairs. I did not put this wiring in someone else replaced the switches and put them back in the incorrect order.
at the landing switch there are three cables one three core and two four core? at the switch the 3 and one of the four core cables neutrals are choc blocked together. all three Live cables were in L2 ?
What I did was to configure the wiring as per a two way switch but this left me with an extra yellow(sleeved) in the landing switch?? All lights work throughout the house apart from the landing light it can only be operated by turning the switch off in the hall only then does the landing light work correctly on and off. I don't understand why there is an extra four core cable at the landing light. Double switch in the hall for upstairs landing light and the hall light. single switch upstairs landing light.? your help is greatly appreciated not only to fix this problem but to educate my knowledge, thank you
