Lighting contactor | on ElectriciansForums
Discuss Lighting contactor in the UK Electrical Forum area at ElectriciansForums.net
A
akcorbin
Evening,
basically I have 3 lighting circuits controlled by a one photocell.
I have fed my photocell and then the switched live from the photocell comes down to my contactor.
My contactor is as follows
1. 3. 5.
A1
A2
2. 4. 6
I have taken the switched live from photocell to a1 and the neutral from photocell to a2.
I have taken my 3 lighting feeds to 2, 4 and 6
I have linked 1,3 and 5 to a1
i have connector blocked my 3 lighting feed neutrals and linked with a2
Please could someone tell me if this is correct?
Many thanks
No in a word.
From the way you describe it it seems that you are using the contactor as a glorified connector block.
The point of the contactor would be to switch live in and live out and or neutrals without running the power through the photocell.
Have you got lighting feeds and supplies or are you only feeding the lights from the contactor?
EDIT: It will, work however it seems a little pointless.
Evening,
1. 3. 5.
A1
A2
2. 4. 6
Many thanks
You have no idea what you are doing,
And you should not be doing it!
Get an electrician to do the job for you.
It will be safer for you.
Your contactor looks to me to be single pole, would be better being double pole so as to isolate the neutrals as well as the lives.
The switchwire from the photocell needs to go into a1 alone. On your contactor 1,3,5 will have the 3 feeds from the fuseboard or 1 feed linked to 3,5. Connections 2,4,6 should be the switchwires as it were to the 3 lighting circuits. So once the photocell activates it pulls in the coil A1 and energizes all the lighting circuits, the neutrals will have to go in a connector block or din rail, A2 needs a neutral to work the coil.
So no point to having the contactor then.
I think Moses makes a good point.
However, very quickly, 3 x times lighting supplies from main board lives through contactor 1 3 5. Lives out to lights from 2 4 6. Join neutrals together seperately.
Feed live and neutral to photocell then switched live and neutral to A1 (switched live) and A2 (neutral).
Good luck but I would seriously take note of what Moses says and get a professional in.
Here's how I'd wire it...
[ElectriciansForums.net] Lighting contactor
***EDIT***
Just noticed the missing neutral to A2. Just take one from neutral bar
Reply to Lighting contactor in the UK Electrical Forum area at ElectriciansForums.net
I think it was too early yes I meant 3 not 2, but great I'll give that a whirl and thanks.
You only need to switch the lines and the contactor is rated per pole so for example a 16A four pole contactor would be fine.
