Currently reading:
Lighting fixture flickers for like 10-15 seconds, just very slightly, then stops
Discuss Lighting fixture flickers for like 10-15 seconds, just very slightly, then stops in the DIY Electrical Advice area at ElectriciansForums.net
Doctrader
Hi! I have a fixture that flickers for maybe 15 seconds when I first turn it on. Then it stops flickering and functions normally.
Then if I were to turn the switch on soon after it stops, there is no flickering.
Then if I wait 30min or so and turn it on again, it flickers just briefly again.
I did change the switch next to it in a two gang to a smart switch that has a neutral, not a dimmer. That switch works fine.
Any thoughts?
Sounds like you may have a loose cable joint somewhere.
What kind of lamp is this? This could be a description of a failing fluorescent fitting.
Reply to Lighting fixture flickers for like 10-15 seconds, just very slightly, then stops in the DIY Electrical Advice area at ElectriciansForums.net
