C
cheesybeanz
I have recently had electricity installed in my shed with a small garage consumer unit (32a & 6a). The sockets are fine and the electrician informed me if I wanted lighting, I was to install it to the 6a breaker which I have done. I have connected everything up but when I turn the breaker on, the whole sockets trip in the house. See pics below
This is the consumer unit. The white cable in the top right is the lighting cable. This is normal 3 core flex with all ends going to correct parts of the unit.
This is my light. Everything is fine here.
This is where I have connected the Neutral and Earth from the light to the main cable.
This is the switch.
I think i have done everything correct which leaves me with the feeling the 3 core flex isn't big enough. Any help is massively appreciated. Obviously, my connector blocks will be insulated when i've finished.
This is the switch.
