lighting joint boxes | on ElectriciansForums
Discuss lighting joint boxes in the UK Electrical Forum area at ElectriciansForums.net
England
Hi Guys, Another little query for those of you that do new house installs. Not practical nowadays to wire light circuits via loop in systems due to modern day downlight recessed fittings and or light fittings designed for 1 cable!
If using joint boxes, lets say in a roof space, therefore accessible for maintenance (although i'd rather not use any anywhere) what type do most of you use? Bearing in mind several cables to be terminated. Years ago I would of used a RB4 joint box with a strip of connectors inside . RB 4 (if correct term( was a square box that basically sandwiched the connection strip, choc block as some call them.
Blimey that was quick! Thanks for reply though. i know you guys use them for d/lights etc. but would you use those for several cables, possibly 7 or 8 T+E cables?
Yes you can get that many 1.0mm or 1.5mm cables in.... for that many though, wagobox can be a bit neater.
I would suggest maybe planning your circuit a bit better with that many cables to joint though.
Yes agree re planning......i've done loop in /out of switches.....even shaver points. but with what customer wants and wall lights etc been difficult not to use joint box. I've reluctantly ended up using one to ease installation. I'll look on wago's web site. i did enquire At Newy & Eyre's, they had nothing.
Reply to lighting joint boxes in the UK Electrical Forum area at ElectriciansForums.net
