lighting problem - please help! | Page 2 | on ElectriciansForums
Discuss lighting problem - please help! in the UK Electrical Forum area at ElectriciansForums.net
L
LayerSeven
hi all,
i installed some new spotlights in a customers kitchen and an external security light about 6 months ago. all went well with the install - test results were good and the lights worked as the client wanted them to (switchable from 3 points in the kitchen).
however, i got a call today to say the kitchen lights and the security light had stopped working. i went round and did some testing on them to try and find out what the problem was but couldnt figure it out. i only had time to do some basic tests as the client couldnt give me much time but what i found was:
  • measured 240v at the switches
  • measured 240v at the light fittings
  • bulbs definitely work, i tried them in a different fitting
  • checked for loose connections at the db, switches and light fittings and found none
  • switch lives and common seem to be working as they should but i need to test again
client says no work has been done to the house or wiring since they were fitted so i'm assuming no damage to cables but i still need to test them.
the only part of the circuit i cant get to for testing is a junction box concealed in the ceiling cavity but if i have to i can cut a hole in the plasterboard to get to it. obviously i would like to avoid this if possible!
anyone come across this before and got any handy suggestions on what the problem might be?
thanks in advance for any help given.
ok, i got...
L-N - no reading
N-E - 230v
L-E - 230v
circuit is wired loop in but with junction boxes. run as an addition to an existing lighting circuit and the original lights are still working
because i put up in the ceiling where it would have been accessible and then the builders came in and moved it (according to the client) first i knew of it being moved was when i went back to do the final fix and testing and by that point the ceiling was in place
Hmmmmm!!!! :smilielol5:
Reply to lighting problem - please help! in the UK Electrical Forum area at ElectriciansForums.net
Fitted a lot of this sort of light recently, with all tests reporting back through central Dali controller(s).
nicebutdim
N
Thank you so much for your help with this light work perfect now thank you again much appreciated
