Lighting problem | on ElectriciansForums
Discuss Lighting problem in the Australia area at ElectriciansForums.net
B
Bubblecraft
Hi there
I have a slight problem. I had put in a full new bathroom & fitted MR16 fittings. Everything is fine with that. The customer then asked me to continue with spot lights throughout the rest of the property which I done about 2 months later. I fitted 16 GU10 fittings & left them hanging down while I plastered & decorated. Now that it's all finished, I tried putting up the fittings & then realised that there is not enough clearance above to put the fittings right up as it's a concrete floor for the above property. Took me a while to figure it out as it worked fine in the bathroom. The problem is that the GU10 bulb with tail is too tall compared to an MR16 & tail.
Is there a smaller GU10 bulb (height) that I could get to save me changing all the GU10's & tails to MR16's with tails & trannies?
Sent from my iPhone using Tapatalk - Couple a' Tools
It is a house. Down stairs is one property & upstairs is another via different front doors. It is a solid concrete floor about 50mm above the PB
Didn't want to put a suspended ceiling in to keep costs down for the customer. Changing to MR16's is a far cheaper option than re- sheeting, plastering & painting just to gain 9.5mm
As I said, MR16's & tails fit fine, GU10's are just a little too tall. I just wondered if there was a smaller GU10 or at least a 240v bulb that will fit in the same holder with a slimmer tail
if the flat above has a concrete floor, i see no need for fire rated fittings. the concrete itself is a fire barrier.
Good point, although some of the new build flats a worked on a couple of years ago they were fitting fire rated ceilings even thought the floor/ceiling divide was concrete. Seems a bit over the top but is why I asked.
Reply to Lighting problem in the Australia area at ElectriciansForums.net
SOLVED Thanks for all the help. It was nothing to do with the smoke detector. In this new hole (where there will be a light fitting) three white...
