View the thread, titled "Lighting problem" which is posted in Australia on Electricians Forums.
B
Bubblecraft
Hi there
I have a slight problem. I had put in a full new bathroom & fitted MR16 fittings. Everything is fine with that. The customer then asked me to continue with spot lights throughout the rest of the property which I done about 2 months later. I fitted 16 GU10 fittings & left them hanging down while I plastered & decorated. Now that it's all finished, I tried putting up the fittings & then realised that there is not enough clearance above to put the fittings right up as it's a concrete floor for the above property. Took me a while to figure it out as it worked fine in the bathroom. The problem is that the GU10 bulb with tail is too tall compared to an MR16 & tail.
Is there a smaller GU10 bulb (height) that I could get to save me changing all the GU10's & tails to MR16's with tails & trannies?
Sent from my iPhone using Tapatalk - Couple a' Tools
16 MR16 bulbs, 16 tails & 16 trannies will cost me £60 so it's the cheaper option. Just a pain having to rewire them all. I've got to take the hit on it as it's my boo boo so cheaper the better
Reply to the thread, titled "Lighting problem" which is posted in Australia on Electricians Forums.
